Forums › Tuning, Modification & Legal › Project Cars › 206 Gt track project |
Posted: Sat Mar 14, 2015 3:05 pm |
Right so its about time I made a project thread for the 206.
The car came to me pretty much standard with a de-cat powerflow exhaust system. Since then I have fitted the following..
Gti 180 inlet manifold.
Gti 180 exhaust manifold.
Gti6 throttle body & ICV.
Small induction kit.
New extended throttle cable.
I have already purchased the cheap FK coilovers in the past.
I have just done some more purchasing and bought the following
Flocked dash
Momo steering wheel
D2 steering wheel boss
Boot plastic trim
A set of 307 16 inch peugeot alloy wheels
Single bucket seat and fittings.
A pipe bender to start the cage project.
new enclosed carbon CDA induction kit.
brake bias valve
new peugeot spark plugs
total Quartz 7000 oil
I will upload some photos when I get round to the car.
| 1999 206 Gt... Gti180 inlet, Gti180 exhaust manifold, Gti180 injectors, Gti-6 throttle body, Custom Adapter pipe to mate the throttle body to intake, Gti180 alternator, Gti-6 ICV, Straight through stainless exhaust system, cat cams (apparently), Avo coilovers, short shift gear stick, stripped out with fixed back bucket seat and harness, flocked dash, momo steering wheel and D2 solid boss, real carbon cold air intake, Gti-6 front calipers and 288mm disks, rear drilled and grooved disks, morette headlights, sp bonnet grill 71,456 miles
2008 Audi A3 2.0 Tdi 170 | |
Posted: Sat Mar 21, 2015 4:36 pm |
206gt160 wrote: |
Hi mate, good to see another track car in the works.
How much experience have you got with building cages?
Raz
Posted: Sat Apr 04, 2015 12:06 pm |
Just purchased the gti6 front disks and calipers and some drilled and grooved rear brakes. Photos will everntually be up.
I have no current experience with fabricating a cage, I will be going off the images I find on google and forums... follwing the bend lines they use. The only way I will gain the ecpierience is by attempting to start building cages. I have been doing a lot of research on them and I feel ready to start the cage build now.
Posted: Tue Apr 21, 2015 9:11 am |
Just bought a set of AVO Coilovers off the internet so the FK coilovers I have are going to be sold soon.
Big day ahead of me tomorrow, I have a lot of work to do..
1) Fit AVO coilovers Done... and lower torsion bar.
2) Fit GTI6 front calipers and disks...Done
3) Fit new passenger door...Done
4) Drill the floor of the drivers seat for the new brackets I have made up to fit the bucket seat.
5) Fit the new alloys with the tyres on the front of the car.
Enough to be getting on with tomorrow.
Flocked dash........DONE
Momo steering wheel..........DONE
D2 steering wheel boss........DONE
Boot plastic trim......DONE
A set of 307 16 inch peugeot alloy wheels......SOLD DIDNT LIKE THEM
Single bucket seat and fittings..........TOMORROWS JOB
A pipe bender to start the cage project........NOT FITTING ONE NOW
new enclosed carbon CDA induction kit........DONE
brake bias valve.....NEXT WEEKS JOB WITH RUNNING NEW BRAKE HOSES]
new peugeot spark plugs........DONE
total Quartz 7000 oil.... DONE
Posted: Wed Apr 22, 2015 1:57 pm |
Few photo's.
Fitted the gti6 front brake set up, new track rod ends.. new drop links.. new passenger door.. AVO coilover suspension. Quite a busy day in the sun
Need to get the wheels on the front to clean up the look.
Posted: Thu Apr 23, 2015 2:45 am |
Just purchased a set of black morette's for the pug. She is atarting to come along very nicely now.
Also bought some Hel braided brake hosing, just need to buy the end fittings now.
Posted: Thu Apr 23, 2015 3:13 am |
Coming along really nice buddy, lots of good progress made in such a short time!
What's your opinion on the AVO's though? These where my 2nd option if I didn't get RSX's?
Posted: Thu Apr 23, 2015 12:54 pm |
The avo setup seem really good i'm really chuffed with how they handle. Will hold up very well on the track day in August.
Posted: Thu Apr 23, 2015 4:16 pm |
206gt160 wrote: |
The avo setup seem really good i'm really chuffed with how they handle. Will hold up very well on the track day in August. |
Thanks for the info buddy
Posted: Mon Apr 27, 2015 8:34 am |
Not a problem.
Posted: Tue Apr 28, 2015 1:38 pm |
Couple more purchases for the 206.
Posted: Tue Apr 28, 2015 4:31 pm |
Bit of work done a few weeks ago.
Posted: Tue Apr 28, 2015 4:33 pm |
Found out there was a leak that found its way under the seat so all the rust has now been removed, treated and resprayed. Going to silicon all of the plastic caps under where the rear seats fit as I have heard they can let water in.
Posted: Wed Apr 29, 2015 2:20 pm |
This is the pvc covered braided line I will be using.. its HEL hose.
The new lights now fitted, just need to sort the passenger side cold intake through the sidelight.
Quite happy with the progress so far.
Soon be ready for the vinyl wrap, I am hopefully going to see the vinyl colours available tomorrow. The company are doing it at cost for a bit of advertising.
Also been in contact with some other companies regarding performance parts at slashed prices for advertising their company. Quite happy as I have managed to get a few big names involved so far!
Posted: Thu Apr 30, 2015 10:42 am |
Here is the flocked dash.. still need to flock the airbag and speedo surround.
This is the seat that I picked up off Ebay with the harness.
