Latest: jeromequi
Overall: 17111
Online Now [20]:
Visitors: 20
Today: 2222
Total: 93654205
Forums › The Car › Solved 206 Problems › 1.1 not starting -SOLVED
David1156
PostPosted: Fri Jun 13, 2014 5:06 pm Up
Hoping someone can help me with this, I got in the car this evening and the car refuses to start. It will turn over once and then the abs and seatbelt light come on along with the handbrake and battery symbol. It was working fine yesterday. Another thing I noticed was that the clock had reset to 0:00 and that when I first tried to start the car, the headlights would flash before the lights on the dashboard show up. There seems to be some sort of clicking noise coming from behind the speedo too before the warning lights come on.
Current: Albi Blue Clio 197
Hawkers
PostPosted: Sat Jun 14, 2014 4:18 am Up
Have you tried another battery?
I have Peugeot Planet/DiagBox.
Previous Car: Peugeot 206 1.4
Now: Peugeot 207 1.6 VTi 120 Sport
PostPosted: Sat Jun 14, 2014 4:24 am Up
Check the earth strap on the gearbox.
doski
PostPosted: Sat Jun 14, 2014 7:12 am Up
check the earth the fuses and also the battery terminals one of mine were loose
David1156
PostPosted: Sat Jun 14, 2014 10:53 am Up
A bit of an update, i've checked the earth strap. There are two cables going from the negative terminal, one to the gearbox and one to what I believe to be another part of metal. Both are secure and seem fine. I've also reset the bsi and it did not help. I haven't tried another battery yet as I have to purchase another one which will have to be done during the week. I'll be checking the fuses under the bonnet and was wondering if I need to disconnect the battery before I check them?
The car was fine yesterday, in a matter of hours this problem occurs. Everytime I try to start the car I also hear a bong noise from the dash. My guess is if the fuses are ok, it must be a bsi related issue. Guess it was bound to happen with a car this old.
PostPosted: Sat Jun 14, 2014 10:55 am Up
Sounds like the battery is flat / dead.
David1156
PostPosted: Sat Jun 14, 2014 11:40 am Up
I have another theory, I braked with my left foot yesterday (don't ask why) and the car stopped immediately as my left leg is used to pressing the clutch pedal with quite a bit of force. I think that this has triggered the fuel to be cut off as the car thinks that it has been in an accident. The fact that the airbag light stays on gives the theory a bit of credibility. Unfortunately I don't have the fuel cut-off inertia switch on my pug.
Post 7: www.bba-reman.com/foru...42058.aspx
Post 1: www.206info.co.uk/Foru...22347.html
Post 5: www.peugeotforums.com/...ting-8327/
DREWDEN
PostPosted: Sat Jun 14, 2014 1:33 pm Up
Noticable sounds of a knackered or flat battery is the bong bong noise.
www.peugeotforums.com/...car-12848/
206 2ltr Hdi glx 53 plate
PostPosted: Sat Jun 14, 2014 2:09 pm Up
Your battery is dead,don't keep starting it,as this will cause problems to the BSI,ECU,and the Speedo needles will die,usually the temp. gauge,and all of this confirmed by the bong,so replace the battery ASAP,and don't keep suggesting things that cause this,you made this thread so we can help you,not to help us,we are here to help you,and by doing what we say this can happen,but if you keep say this or that,your will stay still.
David1156
PostPosted: Sat Jun 14, 2014 2:22 pm Up
Thanks for all the help so far guys. I totally understand Timon and will definitely act upon the advice given by everyone on here. Will get a new battery this week and report back hopefully with good news. Is there any type of battery in particular I should purchase?
DREWDEN
PostPosted: Sat Jun 14, 2014 2:45 pm Up
Try gsf parts, have deals on batteries now and then, BOSCH are good batteries.
They will give you the battery thats needed for your car.
PostPosted: Sat Jun 14, 2014 3:03 pm Up
You are most welcome David,try to get VARTA,it's the best battery,then comes BOSCH,also there is FIAMM,waiting for your report back on results.
PostPosted: Sat Jun 14, 2014 4:02 pm Up
There exactly the same just with different branding.
Varta make the batteries for Bosch Wink
DREWDEN
PostPosted: Sat Jun 14, 2014 4:19 pm Up
Learn something every day, never new that.
doski
PostPosted: Sun Jun 15, 2014 10:24 am Up
bump it
