Posted: Wed Jul 22, 2015 12:53 pm |
Hi,
I've just completed an oil and filter change and decided to go for 5w40 instead of my norm 10w40. However now it's running a bit tappy...... Is this ok as I e never used 5w40 before?
| why wont you work??????????????????? ARGH F**k it!!!!! | |
Posted: Wed Jul 22, 2015 1:00 pm |
Double check dip stick level, run about, and check again until it settles
On a 2000 2.0 HDi I switched to 5w40 during winter, and I think I'll stick with it now, no tapping. It's supposed to be more liquid when cold than 10w (hence the lower number 5w), maybe you hear tapping on your engine.
I used to record the before and after oil change engine sound but never analysed those videos, as simply the difference was ever so faint
Posted: Wed Jul 22, 2015 1:19 pm |
Ive checked and run about and re checked levels and they are fine. The engine sound is a bit tappy.... Could this just be cause it's a "thinner" oil?
Posted: Wed Jul 22, 2015 2:05 pm |
If it's a high miler, use a thicker oil, rather than a thinner oil..
| The Cars:
Peugeot 206 1.6 HDi GTi '06 Plate - O/H's Car | |
Posted: Wed Jul 22, 2015 2:31 pm |
It's on approx 144 thousand. I'll run it tonight and tomorrow morning..., if no change I'll put 10w40 back in.
Pity they don't do a fully synthetic 10w40
Posted: Mon Jul 27, 2015 7:20 am |
I decided to stick it out and the noise has now almost gone. No idea why .
I can report that the car is a bit more .... Let say eager than normal.
