On the dash in front of the clock screen there are the 2 buttons... in the middle there is an LED and when the car is in the ignition the LED is solid, and when the car is running. Recently the car alarm went off and then we had to open the bonnet as the key fob was working no miracles, either in the door or remotely, maybe the battery is low, thanks for your help
Posted: Sat Apr 29, 2017 8:08 am
To shut the alarm up when the keyfob isnt working just turn the ignition ON with the key. The transponder immobilizer chip inside the key will deactivate the alarm system.
Does the red led in the button come on all the time OR just when the doors are locked with the engine running?
Interactive software released under GNU GPL,
Code Credits,
Privacy Policy
