Latest: Mr-Koekwaus
Overall: 17125
Online Now [280]:
Visitors: 279
Today: 5675
Total: 99390939
Forums › The Car › 206 Problems › Unable to get old spark plugs out
Tom240796
PostPosted: Tue Jul 28, 2015 8:35 am Up
i have a 2001 1.4 8 valve 206 and am trying to remove and replace the spark plugs, I have a 16mm spark plug socket and a ball/knuckle joint attachment for the socket as well as two different lengths of extension bars but I am still unable to get the socket into the spark plugs as the throttle body is in the way. Any suggestions would be very helpful, thank you.
darthvalkyr
PostPosted: Thu Sep 03, 2015 5:28 pm Up
Some of the plugs can be a nightmare due to clearance issues with other parts near their holes in the engine block. I resorted to using the socket with an extension bar, and using an adjustable wrench on the square drive part of the extension bar in order to turn them. It's just a case of making the best you can from what tools you have lying around. Good luck.
