Forums › The Car › 206 Talk › 206 Gti 140 poor starting from cold |
Posted: Sun Jan 10, 2016 1:42 pm |
Hi, I have just bought a 2001 206 Gti 138bhp,it has a problem starting from cold,once its warm its fine,does anyone know how to slove the problem, thanks
Posted: Mon Jan 11, 2016 2:53 am |
Check live data on EOBD reader like pp2000 see what all the temp sensors are reading.
Posted: Tue Jan 12, 2016 4:41 pm |
Hi I have changed the temp sensor and air sensor in the throttle body, its still the same,could it be the idle control valve had a reader on it and no faults
Posted: Wed Jan 13, 2016 1:42 am |
Will it start Ok with some throttle applied?
Posted: Wed Jan 13, 2016 3:04 pm |
Hi, yeah you have to give it a little of throttle then leave it, cause if I try to rev it it dies,so I just leave it to tick over then its fine when it warms up. Thanks
