Forums › The Car › 206 Problems › Progressive Springs |
Posted: Thu Dec 10, 2015 1:49 pm |
Should the tighter coils of progressive springs be at the top?
Posted: Thu Dec 10, 2015 4:01 pm |
Won't make any difference which was springs are fitted.
Posted: Fri Dec 11, 2015 9:44 am |
Thx
Posted: Fri Dec 11, 2015 10:42 am |
Won't make any difference unless they don't fit the spring seats correctly.
