Latest: Mr-Koekwaus
Overall: 17125
Online Now [56]:
Visitors: 54
Members: 1
Today: 30987
Total: 99416156
Forums › The Car › 206 Problems › Battery went flat.
Battery went flat.
josh1073
PostPosted: Sat Apr 30, 2016 2:58 pm Up
2004 206 1.1 Car battery went flat as it sat for 3 weeks due to no insurance, took the battery out and its now on a charger is there anything i need to know when i put it back? Like a sequence or code?
Thanks for any replys.
FrankAteMyName
PostPosted: Sat Apr 30, 2016 5:52 pm Up
Ideally you should drop the driver's window and close all of the doors before reconnectiong. Then once it's hooked up turn on the sidelights through the window (Don't open the door). This initiates a 'soft boot' of the BSI. Opening a door may cause the BSI to panic and has been known in rare cases to brick the BSI/ECU. The risk is very low but that's what the folk on here recommend.
My cars:
206 Urban 1.4 8v 3dr '56 - China Blue - 70k Miles - Climate control retrofit, cruise control retrofit - Dead (Breaking)
206 GLX 1.4 8v 3dr '03 - 100k Miles - Obsidian Black - Black masked headlights + front fogs, Faster sunroof, Colour matched exterior trim - SOLD
206 2.0 GTI 138 '03 - 58k Miles - Onyx Black - 17" 180 Alloys - Current
206 2.0 GTi 138 '03 - 120k Miles - China Blue - New Track Toy (ON THE WAY)
David1156
PostPosted: Sun May 01, 2016 2:39 am Up
Pretty much what has been said above but you can also have someone sit in the car and turn the sidelights on. Here's a detailed set of instructions: www.206info.co.uk/Foru...20314.html
Current: Albi Blue Clio 197
