Latest: Mr-Koekwaus
Overall: 17125
Online Now [118]:
Visitors: 117
Today: 35613
Total: 99420777
Forums › The Car › 206 Problems › Horn relay, where is it?
jules206
PostPosted: Wed Aug 10, 2016 8:35 am Up
The horn doesn't work, no 12 volt on multimeter, but the relay clicks when horn button pressed. The 15amp fuse is OK.
I looked in, around and under BM34 engine fusebox, as relay click seems to come from there, but cant see the relay. I want to do a simple swapout.
Where is the horn relay, and what shape, colour, part number is it? I'm guessing it just unplugs for replacement.
Any help would be really useful, I'm sure someone has had the same problem.
PostPosted: Wed Aug 10, 2016 10:14 am Up
It's normally the wiring & connector plug at the horn end that fails / rots out.
Repaired no end of them on 206s.
