Online Now [25]:
Visitors: 24
Today: 11977
Total: 116818901
Forums › The Car › 206 Problems › power on ignition
power on ignition
bloodmeal
PostPosted: Sat Jun 25, 2016 3:07 pm Up
Basically i need a usb power supply to my tablet to be active only when the car ignition is started, not overnight.
i don't mind if its from one click turn or when the engine is running only, as long as the power is off while I'm not using the car.
How hard would this be?
Sim
PostPosted: Sat Jun 25, 2016 10:20 pm Up
Hi, try this one: www.206info.co.uk/Foru...ition.html
Tad more fiddly if your car's multiplexed..
EV (roadtripper)
Jag S(crapped)- & X-Type
GTC VXR (sold)
VorTechS
PostPosted: Mon Jun 27, 2016 7:02 am Up
Staff - Vortechs
CAUTION: If you wire direct from the battery (like I have) you should consider using something that employs a delayed start, and offers surge protection otherwise you risk frying your table during crank.
bloodmeal
PostPosted: Fri Jul 01, 2016 11:07 pm Up
Guys, cant i just go under cigarette lighter in the middle and splice off a wire from + and from - and go straight to a mini usb? ...
bloodmeal
PostPosted: Sat Jul 02, 2016 3:01 pm Up
nobody ?
FrankAteMyName
PostPosted: Sat Jul 02, 2016 3:07 pm Up
Is the car pre or MUX?
You can do but the cig lighter is 12v DC. You need 5V 1A/2.1A. You can do this if you're any good at soldering with a basic voltage regulator. If you put 12v into the tablet you WILL fry it immediately.
Option B is buy a mini USB cig lighter charger and smash up the plug end of it. Circuitry in there will do exactly the same job. You'll just have to frankenstein it together. That's the safest option if you're not confident in component wiring. It is also the messiest looking solution IMO.
Hope that helps
My cars:
206 Urban 1.4 8v 3dr '56 - China Blue - 70k Miles - Climate control retrofit, cruise control retrofit - Dead (Breaking)
206 GLX 1.4 8v 3dr '03 - 100k Miles - Obsidian Black - Black masked headlights + front fogs, Faster sunroof, Colour matched exterior trim - SOLD
206 2.0 GTI 138 '03 - 58k Miles - Onyx Black - 17" 180 Alloys - Current
206 2.0 GTi 138 '03 - 120k Miles - China Blue - New Track Toy (ON THE WAY)
bloodmeal
PostPosted: Sat Jul 02, 2016 3:10 pm Up
Hope that helps
THANKS. thats exactly the advice needed.
i dont mind to break open an old cig lighter charger, but where do i connect it to the car? i dont want it to "take up" my cig lighter if i can avoid it. I was hoping to have everything concealed.
mtempsch
PostPosted: Sat Jul 02, 2016 5:10 pm Up
You can tap into the wire[s] going to the cig.lighter (the negative can be grounded essentially anywhere...) IIRC there are 3 wires: +12 for heating the lighter and this the one you want to connect to, +12 for the illumination, and ground.
. I've wired in a little distribution block to which I've then connected footwell LED's as well as the guts of a USB supply for a dash cam (removed from the clunky cig. adapter plug and stuffed into a plastic electronics project box.
Silvermetallic 2004 206 RC
bloodmeal
PostPosted: Sun Jul 03, 2016 12:00 am Up
Thanks, I wired my footwell neons from the interior light bulb holder and was hoping that this usb would be just as easy.
is there a tutorial around for dismantling a cig lighter charger and splicing it in? (which wires are which etc)
mtempsch
PostPosted: Sun Jul 03, 2016 6:08 am Up
Truly trivial - usually just held together with a screw or two, or even just snapped together. If unlucky they've used glue and you might need more brute force, snips or a dremel...
The wire that connects to the bottom centre pin is +12, the one/two pieces of springy metal on the side is ground.
See image for an example: www.dropbox.com/s/jl6h...dapter.jpg
