Forums › The Car › 206 Talk › Battery earth cable : £113! |
Posted: Thu Dec 08, 2016 12:46 pm |
When putting my 206 back together I noticed the cable where it joins the gearbox earth terminal is looking a little bit past its best. So I thought I'd look at what Peugeot charge for a replacement. £113!
I think kind will be buying some new terminals and cable and making myself a new earth lead!
Posted: Thu Dec 08, 2016 1:15 pm |
Unbelievable price! Maybe its diamond plated?
Posted: Thu Dec 08, 2016 5:00 pm |
Forklift battery cable & crimped on terminals would be my solution.
Posted: Thu Dec 08, 2016 5:17 pm |
Even Halfords sell earth cables that are less than £10
Posted: Thu Dec 08, 2016 6:32 pm |
It's a part that has gone up in price stupidly. Back in 2011 when I had one for my 1.4 direct from Peugeot it was £28 if I remember rightly, may have even been slightly less than that. But when i came to need another one for the GTi 2 years later it had gone up to over £90 so I went with the halfords option. They must have gone up again since.
