is it possible to use delphi to bleed the brakes on my 206 gti 180. if so do you know how to or can you pint me in the right direction for a guide or is it something what i will definitely need peugeot planet for??
thanks for any replys and help
Sim
Posted: Wed Apr 19, 2017 11:21 am
Modern cars need their ABS pump primed to get rid of any air there. Delphi DS has that option as shown here, and you could have a go with someone in the know (they're the brakes mind! )
If you still have spongy brake pedal after it, then it really means Peugeot Planet is your last resort (find our member on PP2000 map nearby you and send them a message!)
The reason only PP2000 might help in the end, is because your 180 is equipped with ESP/ASR, and there are more moving parts involved in the brake system, that need scrupulous bleeding
Interactive software released under GNU GPL,
Code Credits,
Privacy Policy
