Latest: BootIt
Overall: 17110
Online Now [26]:
Visitors: 25
Today: 5655
Total: 93386788
Forums › The Car › Solved 206 Problems › Engine bay noise after ignition shutoff (video)
xrblue
PostPosted: Sun May 21, 2017 5:18 pm Up
m.youtube.com/watch?v=qxlNQLG76Pw
Hi
In need of help.
Its been doing this for a while but now Im having starting problems.
I need to give it some throttle to get it started but still drives well.
Any ideas?
2004 1.4i 206
PostPosted: Thu May 25, 2017 8:55 am Up
Well you have a problem with your ICV ( Idle Control Valve),the sound you hear is the sound of it moving while it moves to it's rest position,It's faulty,you need to check it,and see what is wrong,as it's the main reason that you have starting problems.
Here is a link on how to take the throttle body off and clean it,you will see the ICV,but there is no need to take the (Throttle Position Sensor -TPS-)
How to clean throttle body
Good Luck,
Tim
xrblue
PostPosted: Sat May 27, 2017 6:42 pm Up
Tim you are a Diamond!
Problem solved.
Thank you
2004 1.4i 206
PostPosted: Tue May 30, 2017 8:23 am Up
Problem solved.
Thank you
You are Welcome :),glad that I helped you to solve your car problem,and Thank you Smile
