Latest: BootIt
Overall: 17110
Online Now [29]:
Visitors: 28
Today: 4833
Total: 93385970
Forums › The Car › 206 Problems › Clutch switch problems
jasonada
PostPosted: Mon Oct 02, 2017 3:38 pm Up
Hi all I've recently purchased PP2000 with diagbox as I wanted to fit cruse control to my 206 but I ran a global test just out of interest, it came up with just one error (intermittent fault. clutch switch signal no signal or signal not coherent).
So ive replaced the switch and cleared the fault codes but I plugged it back in today and same fault and some times car is really slow to pick up and occasionally hesitates / stutters. And sometimes it just drives as normal so I'm puzzled has any one got any ideas please my car is a 2003 206 1.4hdi eco 70 thanks Jason
gazza82
PostPosted: Wed Oct 04, 2017 6:13 pm Up
Mine has done that ... 2002, same model ... but ....
There isn't a clutch switch ... hunted high and low and had strained back muscles to prove it.
Not long after I had power issues which turned out to be the cat. The internals collapsed into a ball shape and if it rolled in wrong way it blocked the exhaust outlet. It had one flattish side which allowed the gases to escape so occasionally it was fine.
Cured with big hammer and steel bar ...
