Latest: evert
Overall: 17112
Online Now [23]:
Visitors: 22
Today: 7797
Total: 93704975
Forums › The Car › 206 Problems › Wiring my subwoofer
Wiring my subwoofer
Yuvalh19
PostPosted: Mon Feb 19, 2018 6:37 am Up
Hello
I having trouble to fine the gormet in the firewall
That i need to pass through him my power cable to the sub.
Anypne knows where i can find this in my 206?
RYMAN
PostPosted: Mon Feb 19, 2018 7:40 am Up
From memory it's behind the glove box. Should be a rubber grommet already there, take that out and there will be a plastic "hole" that will need to be drilled.
Uz
PostPosted: Thu Feb 22, 2018 3:48 pm Up
Behind the passenger side front turret in the engine bay, you’ll see the speaker for the alarm sounder there is a rubber grommet... with a rod push that through and you’ll be able to go through that for you power cable. Use the grommet for the seal on the power cable with a bit of waterproof sealant just it water tight.
