Can I swap the front normal Pug 206 seats with the front GTI leather seats? Also are there any guides out there to make this happen? Many thanks
Posted: Wed May 16, 2018 1:33 pm
Depends if your 206 has side airbags fitted in the seats.
Front seats are simple 4 x bolts, 1 bolt in each corner of the seat rail.
If airbags are fitted then make sure the ignition is switched OFF before disconnecting the connector plugs & make sure the replacement seats have the same type of connector plug ( 2 x different types of plugs used on 206 & there not interchangeable )
Interactive software released under GNU GPL,
Code Credits,
Privacy Policy
