Forums › The Car › 206 Problems › What is this connector? GTi138 |
Posted: Sun Sep 09, 2018 11:44 am |
Simple one: What is this connector? Where does it connect to?
It's been 3 years since I took the engine out and i can't remember where everything goes...
Posted: Sun Sep 09, 2018 3:28 pm |
Crank sensor? Oil level sensor? Depends which part of the loom it's on. Coolant sensor is just two wires.
