Once noticed the way the airbox sits on an NFU (TU5JP4) engine (the version with an elongated air filter), that's rubbing against the coolant hose clip to the point it broken through the plastic. I don't think it affects the intake air temperature (negligible), but still..
The simple "fix" is to twist the hose so that the clip points away from the plastic.
Check your engine bay if matches description, as incidentally a 2nd hand replacement part I received also had the same marks:
(now.. no comments on the indented shapes please )
Interactive software released under GNU GPL,
Code Credits,
Privacy Policy
