Latest: heikkisj
Overall: 17126
Online Now [73]:
Visitors: 72
Today: 16958
Total: 100300876
Forums › The Car › 206 Problems › 206 No Heat From Heater
Go to page Previous  1, 2, 3
PostPosted: Tue Aug 04, 2020 7:21 am Up
Its an old engineers trick - must be NON bio.
I used it on my old TU3 powered 206 to clean out the mucky cooling system - also smelled very nice during the flushing session.
clicon357
PostPosted: Tue Aug 04, 2020 8:07 am Up
So how do you do it as in ratio wise, powder to water?
Cheers
..........I can\'t help it I just like French cars!
PostPosted: Tue Aug 04, 2020 8:55 am Up
A scoop or capful in the expansion bottle is enough.
Drain the system first, fill with plain water just below the minimum level on the expansion bottle then add the washing detergent - top the level up to max mark then refit the cap & run the system up to temperature - remember to set the heater to hot.
ekjdm14
PostPosted: Wed Aug 05, 2020 11:21 am Up
Shouldn't make a difference on PSA cars as they don't use the silly clog/leak prone heater valve & control the heat by a flap in the heater box.
+'99 306 2.0SE cabriolet
+'97 306 1.9LXDT
French Car Forums
clicon357
PostPosted: Wed Aug 05, 2020 4:58 pm Up
Thanks. After draining and filling with plain water do I bleed the system? This so the cooling system is full whilst it's cleaning with no airlocks. I've bled up until now via the top hose going to the heater matrix. I put a rubber glove on (saves scalded fingers) then as soon as the air stops coming out quickly screw the little cap on.
That's another gallon of OAT I'll need to buy!
Page 3 of 3
