Latest: jeromequi
Overall: 17111
Online Now [25]:
Visitors: 23
Members: 1
Today: 5236
Total: 93644030
Forums › The Car › 206 Talk › MFD retrofit
MFD retrofit
rallakias
PostPosted: Fri Nov 27, 2015 6:40 am Up
hello i am from Greece...i bought a used peugeot 206 1.4 hdi of 2005...
i've read (http://www.206info.co.uk/Forums/viewtopic/t=20541.html) and i think my 206 is plexed...
I want to retrofit the large MFD unit and activate the trip computer but my 206 has only a digital clock...the plug of the clock has 5 wires...i also have the temp sensor to the right mirror
i've already check too many posts in the forum but i can't figure out if this conversion is possible in my case
rallakias
PostPosted: Fri Nov 27, 2015 1:32 pm Up
i found this www.berlingoforum.co.u...age-4.html
is this guide possible to be used to my 206?
nuwan
PostPosted: Sat Sep 26, 2020 12:22 am Up
Hi rallakias,
Were you able to get this fix?
RocknRolla_zg
PostPosted: Sat Sep 26, 2020 8:03 am Up
If it's multiplex then it's possible. You need a mfd with 2 lines, and you need to modify right steering stalk (on top).
I came, I saw, I conquered.
gazza82
PostPosted: Sat Sep 26, 2020 9:58 pm Up
And then it still might not work 100% ... you will probably need PP2000 too
