Forums › The Car › 206 Problems › 140 and 180 wiring loom |
Posted: Wed Dec 30, 2020 9:14 am |
Hi all
Would i be able to use a 180 wiring loom on a 140 engine? I know there might be a couple of spare sensor connectors.
Thank you for your help
Posted: Wed Jan 20, 2021 8:22 am |
Depends on the age of the car, they did change the plexing after the first 2001 role out. Not sure when though, so could be quit different. e
Posted: Wed Jan 20, 2021 6:58 pm |
The 180 inlet is all different though so connectors might not reach to the correct place. Cam sensor is in a different place too.
