![](themes/base/images/spacer.gif) |
![](themes/base/images/titleTL.gif) |
Forums › The Car › 206 Problems › what does this fault light mean? |
![](themes/base/images/titleTR.gif) |
![](themes/base/images/titleBL.gif) |
![](themes/base/images/titleBR.gif) |
![](themes/base/images/forums/otl.gif) |
Posted: Sun Nov 27, 2022 5:58 pm |
Hello everyone,
does anyone know what this fault light means?
![](https://i.imgur.com/FXCYTHc.jpg)
Peugeot 206 cc 2003
greetings
| | ![](images/spacer.gif) |
Posted: Sun Nov 27, 2022 9:38 pm |
Boot is open?
| ![](themes/base/images/forums/otr.gif) |
