Latest: Worthy967
Overall: 17143
Online Now [749]:
Visitors: 748
Today: 109131
Total: 114845073
Forums › The Car › 206 Problems › 206 1.4 HDI alternator change
MickyP
PostPosted: Tue Sep 05, 2023 5:21 pm Up
Is it a hard job? I can see it's hidden under the power steering pump, but once that's off is it easily accessible?
Thank you!
Car's a 2005 reg.
Sim
PostPosted: Wed Sep 06, 2023 7:31 pm Up
Some 1.4 HDis have an aluminium heat shield (lined with resistant material), once that's out, removing power steering pump should be easier due to better clearance that your turbo design allows.
If you unclip the power steering hoses (low and high pressure), you should be able to move the PAS pump out of the way just enough to get to the alternator bolts.
Saving you from flushing the power steering fluid.
But if high-pressure pipe must get undone, then at least try not to disconnect the bottom low-pressure rubber hose, because without special tools I could never refit it without trickle leaks thereafter.
Take care of the spacer and collar bits surrounding some PAS pump and alternator bolts, some of them do not need to be undone completely to remove the components, also ensure they go back in the same way round on the bolt.
I recall GSF Car Parts selling alternators with surcharge, than they then refund you upon giving up your old broken alternator to them.
Some bed-reads before the big day:
www.youtube.com/watch?v=7Rug1wjdO4k
www.youtube.com/watch?v=UpiDJyWmhtw
www.youtube.com/watch?v=ccY90feu0uU
EV (roadtripper)
Jag S(crapped)- & X-Type
GTC VXR (sold)
gazza82
PostPosted: Wed Sep 06, 2023 9:58 pm Up
When I had to take the manifold off to replace a core plug in the head I did look at taking the steering pump off ... and for the life of me couldn't work out how! ??
Sim
PostPosted: Thu Sep 07, 2023 10:24 am Up
The two PAS pump bolts are accessed from the drive belt's side. Need to rotate the pump to align the circular cutouts, and use a longer Allen key socket.
Thanks for jolting my memory, now that heat-shield should actually not be too much in the way!
To be precise, if you unclip the brackets that hold them, to maneuver them out, i.e. avoid unscrewing/removing them pipe/hose from the PAS itself, if possible.
It's a tight work (if you don't do "the front fell off" approach), and access from underneath the car is just as important (the A/C pump doesn't need to be removed).
EV (roadtripper)
GTC VXR (sold)
MickyP
PostPosted: Thu Sep 07, 2023 6:22 pm Up
Thanks all!
