Forums › The Car › 206 Talk › VIN decoding |
Posted: Thu Oct 12, 2023 10:22 am |
Hi. I don't know if anyone is still doing specs from VINs, but if anyone is, I'd be most grateful if they could please do mine.
VIN is VF32AKFUF43658431
Thanks in advance
Chris
Posted: Sat Oct 14, 2023 7:51 am |
Here you are:
Code:: |
Vehicle characteristics
Vehicle family 206
AS/RP N° 09876 83 1 0345
Warranty Start Date 05/04/2004
Engine serial number 10 FE01 0000297
BER e2*2001/116*0291*00
General information
PRODUCT TYPE PASSENGER CAR
COMMERCIAL MARQUE/COMPONENT TYPE PEUGEOT
VEHICLE FAMILY 206
SILHOUETTE 5 DOOR SALOON
TRIM LEVEL LEVEL XT PREMIUM
ENGINE INJECTION ET3J4
TRANSMISSION BVM5
PAINT TYPE METALLIC PAINTWORK
BODY COLOUR ETS - ASH GREY PAINT
INTERIOR TRIM TYPE VELOUR ENJOY F791 + MISTECO F685 "RN"
UPHOLSTERY COLOUR "FS"
GEARBOX (CHARACTERISTICS) BVM MA5 / N
ENGINE (TYPE) ENGINE TYPE ET
OTHER BADGE WITHOUT FULLER BADGE
OTHER BADGE, " MISC. " WITHOUT FULLER BADGE
BADGE WITHOUT BADGE
STEERING UNVARIABLE POWER STEERING
SPEEDOMETER DRIVE TACHO TORQUE 19X17
Fuel supply-Engine
FUEL FILLER CAP FUEL CAP WITHOUT LOCK
DIESEL FILTER WATER DETECTOR WITHOUT DIESEL FILTER WATER DETECTOR
CYLINDER BLOCK (MATERIAL) CRANKCASE ALUMINIUM
FUEL UNLEADED PETROL 95 QUALITY A/B/E/E+
EMISSIONS STANDARD (ENGINE) EURO 4 ENGINE EMISSION CONTROL
PRE-FILTER ASSEMBLY WITHOUT PRE-FILTER
CATALYTIC CONVERTER 3-COMPONENT RHODIUM+PLATINUM FILTER CATALYSER
OIL COOLER WITHOUT OIL-WATER DISTR CHAMB
OPTIMISATION OF VEHICLE’S CONSUMPTION WITHOUT FUEL CONSUMPTION OPTIMISATION
COOLING MOTOR RADIATOR TH : 18-21 DM2 PAS 1 ALUMINIUM MECHANICAL
CRANKCASE GAS CIRCUIT HEATING W/O HEATER CASING GAS CIRCUIT
FUEL SUPPLY CUTOFF FUEL FEED CUT-OFF
RHEOSTAT RHEOSTAT
EOBD SELF-DIAGNOSIS SYSTEM "EOBD" AUTO-DIAGNOSTIC WITH ACCELEROMETER
DEVICE (ANTIPOLLUTION) WITHOUT ANTI-POLLUTION DEVICE
VEHICLE TECHNICAL DEPOLLUTION EURO 3 L4 VEHICLE TECHNICAL EMISSION CONTROL
PARTICLE FILTER WITHOUT PARTICLE FILTER
FAN 1 FAN - 2 SPEEDS 250W 70WAERO
FUEL VAPOUR RETRIEVAL CONTROLLED PETROL VAPOUR RECUPERATION
INJECTION ASSOCIATED VARIANT MOUNTING MAGNETI MARELLI
TANK FILTER RESERVOIR FILTER INTERIOR
THROTTLE HOUSING (ENGINE INLET AIR CIRCUIT) MOTORISED THROTTLE BODY (ENG AIR INTAKE)
STOP AND START WITHOUT STOP AND START
Gearbox Transmission
TRANSMISSION BVM5
FINAL DRIVE RATIO REAR AXLE HYPOID GEARSET 16 X 65
WHEEL STYLE 14 INCH STEEL WHEEL
GEARBOX SAFETY LOCK W/O G/BOX SECURITY LOCKING
GEARBOX TYPE (TYPE APPROVAL) GEARBOX MA/5 N TYPE
DIFFERENTIAL (GEARBOX) DIFFERENTIAL 68
TYRE (SIZE, TYPE) 175/65 R14 82T NON REINFORCED TYRE
WHEELS FITTED 5,5" RIM ROAD WHEELS
WHEEL (TYPE) STEEL WHEELS
GEARBOX TYPE MA
Suspension-Steering-Brakes
ABS WITH ABS BRAKES
REAR ANTI-ROLL BAR ANTI-ROLL BAR DIAM 19
FRONT ANTI-ROLL BAR FRONT ANTI-ROLL BAR DIAM 20
SERVICE BRAKE ELECTRONIC BRAKEFORCE DISTRIBUTION
BRAKE TYPE VENTILATED FRONT DISCS/REAR DRUMS
SUSPENSION NORMAL SUSPENSION
DYNAMIC STABILITY CONTROL SYSTEM WITHOUT ELECTRONIC STABILITY PROGRAM
BRAKE ASSOCIATED VARIANT ABS TEVES MK70
PEDAL BRACKET (TYPE) PEDAL STANDARD
Body fittings
HORNS HORN STANDARD
AERIAL SHORT ROOF AERIAL
FINISHER (SELF-ADHESIVE) MATT BLACK REAR SURROUND TRIM
SIDE MOULDINGS (TYPE) LATERAL PROTECTOR MASS TINTED
WHEEL EMBELLISHER (STYLE) CUBA STYLE 8 HOLES 14 INCHES
ADDITIONAL SHIELD (UNDER ENGINE) W/O ENGINE UNDERSHELDING
EXT. REARVIEW MIRROR COMP. FUNCTION EXT MIRROR MANUAL-FOLD BACK
EXHAUST TAILPIPE TRIM W/O EXHAUST OUTLET EMBELLISHER
ENGINE BAY SOUNDPROOFING BULKHEAD SOUNDPROOFING
WINDSCREEN WIPER FRONT WIPER BLADE WITH RAIN SENSOR
REAR SCREEN WIPER REAR SCREEN WIPER
HEADLAMP WIPER W/O HEADLAMP WIPER
FRONT PANEL BLANK WITHOUT FRONT BUMPER PLUG
ROOF GLASS WITHOUT ROOF WINDOW
BUMPER FR STANDARD CC + CHROME TRIM - RR SPORT CC
MUDFLAP REAR WHEEL FRONT MUDFLAP
LUGGAGE RACK MOUNTING WITHOUT ROOF BARS
FRONT FOGLAMP FRONT FOG LIGHTS
SPECIAL HEADLAMP (DOUBLE OPTIC) DOUBLE OPTIC LAMPS
EXTERIOR REAR VIEW MIRROR (DRIVER SIDE) DRIVER’S DOOR MIRROR ELECTRIC CONTROL
EXTERIOR REAR VIEW MIRROR (PASSENGER SIDE) PASS EXT RRVIEW MIRROR NON HEATED ELECT CNTRL
SPARE WHEEL EMERGENCY WHEEL
EXTERIOR ACCESSORIES BODY COLOURED EXT HANDLES + EXT MIRROR
EXT. REAR VIEW MIRROR (DRIVER SIDE RADIUS) EXT MIRROR ASPHERICAL GLASS
SUN ROOF FIXED ROOF
BUMPER TRIM DYED BUMPER STRIP
REAR WINDOW (TYPE) REAR GLASS HEATED
GLASS (APPEARANCE) TINTED
REAR QUARTER WINDOW (TYPE) WITHOUT REAR QUARTER GLASS
WINDOW (TYPE) ATHERMAL WINDSCREEN
Interior fittings
ANTI-THEFT ALARM WITHOUT THEFT PROTECTION ALARM
CIGAR LIGHTER FRONT CIGAR-LIGHTER
REAR HEAD RESTRAINT REAR HEADREST ADJUSTABLE
FRONT HEAD RESTRAINT JOINTED FRONT HEADREST
REAR SEAT SEPARATE FOLD BACK BENCH SEAT
LUGGAGE COVER WITHOUT LUGGAGE COVER
REAR SEATBELT REAR 3-POINT 3 INERTIA REEL SEAT BELT
FRONT SEATBELT PYROTECHNIC SEAT BELT WITHOUT ALARM
CLIMATE (AMBIENT TEMP) TEMPERATE COUNTRIES
AIR CONDITIONING HEATER MATRIX WITH REAR HEATING
SPEED GRADUATIONS SPEED GRADUATION IN MPH
GRAB HANDLES PASS FR HANDLE + REAR + HOOK
TACHOMETER REV COUNTER WITH NEEDLE
RADIO EQUIPMENT FEED AERIAL RECEIV FRT SPEAKER TWT REAR SPEAKER
CONSOLE CONSOLE WITH REAR HEATING
DRIVING POSITION RIGHT HAND DRIVE
REMOTE CONTROL REMOTE CONTROL ASSEMBLY
ADDITIONAL HEATING WITHOUT ADDITIONNAL HEATING
LOAD SPACE LIGHTING GLOVE-BOX LIGHTING
BOOT AND LOAD SPACE LIGHTING AUTO BOOT LIGHT OR LOAD VOL SWITCH
DASHBOARD EQUIPMENT SHINY FASCIA + GREY BUTTON
MISC. INT. LAMPS MAP READING LAMP
INSTRUMENT PANEL (CHARACTERISTICS) GRADUATION 220 KM/H OR 135 M/H BLACK LAND CL CHROM
TACHOMETER (SIGNAL CONNECTION) REV COUNTER CALC
CHILD SEAT ANCHORING POINTS WITHOUT CHILD SEAT MOUNTING
LOUDSPEAKER 4 FR SPEAKERS (2 TW + 2 FR) + 2 RR SPEAKERS
RADIO CONTROLS REMOTE RADIO CONTROL WITHOUT CD FUNCTION
FRONT PASSENGER SEAT HEIGHT CONTROL WITHOUT FRONT PASSENGER SEAT HEIGHT ADJUSTMENT
DRIVER SEAT ADJUSTMENT DRIVERS FIXED LATERAL BEARING
FRONT PASSENGER SEAT ADJUSTMENT PASSENG FIXED LATERAL BEARING
DRIVER’S SEAT FOLDING W/O FOLDING DRIV FRONT SEATING
FRONT PASSENGER SEAT FOLDING W/O FOLDING PASS FRONT SEATING
EXTERIOR TEMP. INDICATOR EXT TEMP INDICATOR
COMPACT DISC MOUNTING COMPACT DISC
STOWAGE BIN WITHOUT SETTING BOX
SATELLITE NAVIGATION SYSTEM WITHOUT NAVIGATION SYSTEM
REAR WINDOW LIFT ELECT CONTR RR WINDOW LIFTER + LOCK SYSTEM
DRIVER’S WINDOW LIFT SEQUENTIAL DRIVER’S ELECTRIC WINDOW
PASSENGER’S WINDOW LIFT ELEC CNTRL PASS FRONT WINDOW LIFTER
DISPLAY DISPLAY (RADIO+CLOCK AND OR TEMP, CD)
CLOCK NUMERIC CLOCK
OIL GAUGE OIL TEMP + LEVEL INDICATOR
HEATING ELEMENT NON HEATED SEAT
FRONT LATERAL AIRBAG WITHOUT FRONT SIDE AIRBAG
PASSENGER AIRBAG PASSENGER AIRBAG
ON-BOARD COMPUTER COMPUTER
EQUIPMENT PACK W/O EQUIPMENT PACK
EXTERIOR REAR VIEW MIRROR (HEATED) HEATED DOOR MIRROR
AIRBAG DEACTIVATION MANUAL AIRBAG DEACTIVATION
INTERIOR DOOR CONTROL (APPEARANCE) CHROME FINISH INSIDE DOOR HANDLE
FRONT SEAT GUARD WITHOUT CAB PROTECTION PANEL
FRONT SUN VISOR DRIV+PASS SIDE (W/O NOTICE)
RADIO RECEIVER "RD3" RDS COMPACT DISC AUDIO SYSTEM
REFRIGERATION AUTOMATIC AIR CONDITIONING
CRUISE CONTROL WITHOUT SPEED CONTROL
DRIVER’S SEAT HEIGHT CONTROL PARALLEL DRV HEIGHT ADJ
RHEOSTAT RHEOSTAT
STORAGE (OTHERS) STORAGE COMPARTMENT FR + RR DOORS + WALLET
CARPET COVER W/O CARPETMAT
DRIVER AIRBAG DRIVERS AIR BAG
LOAD SPACE STORAGE WITH BOOT TIDY
CARPET F550 PILE CARPET
LIGHTING TIMER NOT ADJUSTABLE TIMER
SWITCH ELECTRONIC ANTI-THEFT KEY
TRIM ADAPTATION PLAST GAIT+ LEATH G/KNOB + BLACK INSERT ALU MA
EQUALISER AMPLIFIER WITHOUT EQUALISER AMPLIFIER
LOCKING CONTROL SIMPLE CENTRAL LOCKING
STEERING WHEEL LEATHER STEERING WHEEL 3 BRANCHES
STORAGE SPACE LOCKS BOLT ON GLOVE-BOX
Electrical
ALTERNATOR ALTERNATOR 70 AMP
HORNS HORN STANDARD
BATTERY BATTERY LO 250
STARTER MOTOR STARTER MOTOR CL 2
SPECIAL LIGHTING AUTOMATIC HEADLAMP ILLUMINATION
MULTIPLEXING MULTIPLEXING ASSEMBLY
Component manufacturers
Miscellaneous
SPECIAL SPECIFICATION STANDARD
ATMOSPHERIC CONDITIONS NORMAL ATMOSPHERE
FIRST AID KIT FIRST AID KIT PACKAGING
RADIO HEADPHONE SOCKET WITHOUT ACCESSORIES SOCKET
SIDE IMPACTS DOOR WITHOUT REINFORCEMENT
SET OF KEYS 1 HF PLIP KEY + 1 SINGLE MAIN KEY
SURFACE CONDITIONS GOOD TERRAIN
SPEED MONITORING WITHOUT SPEED CHECK
EMERGENCY WARNING TRIANGLE WITHOUT WARNING TRIANGLE
