fixed
fluid
User Info
Latest:
slaapkonijn
New Today:
0
New Yesterday:
1
Overall:
17169
Online Now [204]:
Visitors:
203
Bots:
1
Members:
0
Today:
24964
Total:
128690659
Main Menu
General
News
Surveys
Forums
Info Goodies
Links
Member Map
Order a Site Sticker
Search
Search Forums
Web Stats
Statistics
Top 10
Members
206Info Meet Map
206 Info Calendar
My Account
Trade Rating
Site Introduction
Forums › Request a how-to › Post a reply › Re: How to fit Glove Box Light
Forums Home
Forum FAQ
Search
Forum Index
Request a how-to
Username
Subject
Message body
Emoticons
More smilies
Default
Dark Red
Red
Orange
Brown
Yellow
Green
Olive
Cyan
Blue
Dark Blue
Indigo
Violet
White
Black
Tiny
Small
Normal
Large
Huge
[quote="macca1411"]You need to check if the wires are already behind the glove box. It's been a couple of years since I did mine and I can't remember what colour plugs they were. Just put you hand up behind and on top and you should feel them. Have you already got the cut out in the glove box? You can buy the lamp unit and switch from the dealers, used to be less than £10 for the two items. Feed one of the block connectors through the hole in the glove box and connect it nto the lamp, push into place. There should be a small square hole at the bottom right of the glove box where the lid closes against. Push the other connector through this and plug it into the switch, push the switch into place. Job done. If the connectors aren't already there, then you will need to find a switched live feed and create the circuit yourself. 6362C8 (until RPO 08210) Lamp unit £12.89 6362N6 (from RPO 08211) Lamp unit £3.74 633918 Switch £3.54 The RPO number should be on the sticker inside the drivers door jam or on the top of the strut mount under the bonnet.[/quote]
Options
HTML is
ON
BBCode
is
ON
Smilies are
ON
Disable HTML in this post
Disable BBCode in this post
Disable Smilies in this post
Topic review
GNU GPL
Code Credits
Privacy Policy
