Author Message
thompson69
PostPosted: Fri Feb 04, 2011 4:28 pm    Post subject: Re: How to remove front hub
you have to take the bottom arm off and undo the driveshaft and undo the bolt 2 take it of the shocker
take the bottom arm off the hub
Paddy_XSI
PostPosted: Fri Feb 04, 2011 4:21 pm    Post subject: How to remove front hub
Need a good how to on how to remove front hub. If it helps I have a XSI 1.6 16v with ABS.
Currently stuck on my drive on a jack as it needs its hub removing.
Any help appreciated.
