Author Message
Mowle5677
PostPosted: Mon Feb 07, 2011 12:34 pm    Post subject: Re: Changing the colour of the speedo lights.
Yeah put it up and I'll see if it helps Smile
glenpring
PostPosted: Mon Feb 07, 2011 1:21 am    Post subject: Re: Changing the colour of the speedo lights.
I don't know if it would help I have done it on my 307 but if you think it will I'll put something up
almir92
PostPosted: Sun Feb 06, 2011 5:48 pm    Post subject: Re: Changing the colour of the speedo lights.
Mowle5677 wrote:
How do you change the colour of your speedo lights and does anyone have a website where I can buy the stuff?
if you could supply pics when you do it you would be helping a lot (y)
almir92
Mowle5677
PostPosted: Sun Feb 06, 2011 5:17 pm    Post subject: Re: Changing the colour of the speedo lights.
onHow did it turn out?
glenpring
PostPosted: Sun Feb 06, 2011 1:08 pm    Post subject: Re: Changing the colour of the speedo lights.
I have some spair blue SMd LEDs from when I did my clocks if anyone is intrested pm me I have 20 blue ones
PostPosted: Sun Feb 06, 2011 12:54 pm    Post subject: Re: Changing the colour of the speedo lights.
Mowle5677 wrote:
Have you got a link to a lockwood kit?
ebay will have them Wink
to fit the lockwood kit you will need to take the speedo apart to fit.
changing just bulbs you just need to change the bulbs as long as yours is twist bulbs.
Mowle5677
PostPosted: Sun Feb 06, 2011 12:52 pm    Post subject: Re: Changing the colour of the speedo lights.
eddrj
ok thanks
PostPosted: Sun Feb 06, 2011 12:51 pm    Post subject: Re: Changing the colour of the speedo lights.
Mowle5677 wrote:
Thanks buddy. Iv done the clock light which was a pain but I done want to take apart the speedo unit again as I mucked my old one up Sad
im 90% sure your 2000 model will be twist bulbs that are easy as pie to change, just need to remove the speedo surround, take out the screws that hold the unit inplace, pull it forward and twist out each bulb and put new one in.
PostPosted: Sun Feb 06, 2011 12:49 pm    Post subject: Re: Changing the colour of the speedo lights.
eddrj wrote:
anyone got any pics how them blue bulbs would look ?? if there off colour a bit .
Are lockwoods much better ??
i have tried both and the lockwood looked 100% better imo,
i fitted xeon white leds behind the lockwoods to make them bright and crisp.
eddrj
PostPosted: Sun Feb 06, 2011 12:46 pm    Post subject: Re: Changing the colour of the speedo lights.
anyone got any pics how them blue bulbs would look ?? if there off colour a bit .As dash has orange filter
Mowle5677
Jay794
PostPosted: Sun Feb 06, 2011 12:36 pm    Post subject: Re: Changing the colour of the speedo lights.
Nick180 is doing mine at the moment as you have to solder new SMD LED's on the newer models, older ones are just twist and replace. The ones that NorthantsBen referred to will only work on older models
PostPosted: Sun Feb 06, 2011 12:31 pm    Post subject: Re: Changing the colour of the speedo lights.
you can change the bulbs for somthing like these....
cgi.ebay.co.uk/10-X-CA...3387wt_989
or
cgi.ebay.co.uk/10-Blue...117wt_1139
but the dash has a orange filter so colour looks slightly off imo,
best way i found to change the colour was lockwood dial kit.
