| Author |
| Seabook |
Posted: Fri Mar 25, 2011 9:16 pm Post subject: Re: how to wire a turbo timer on a 138 gti so the a\c works |
| 15 mins idle on start up is never a good idea..... |
| MALLE |
Posted: Fri Mar 25, 2011 1:43 pm Post subject: Re: how to wire a turbo timer on a 138 gti so the a\c works |
| Over here is very hot so about 15 mins befor I leave work I go out turn the car on and let it run with the ac running to cool the car down inside but I have to stay with it so if the ac works with the timer I can leave it to run lock it and finsh work rhn go baqck to a cool car don't have a remote start so |
| E5GDM |
Posted: Fri Mar 25, 2011 1:20 pm Post subject: Re: how to wire a turbo timer on a 138 gti so the a\c works |
| If your not in the car for the minute it's running, why do you need the a/c on? |
| MALLE |
Posted: Fri Mar 25, 2011 12:42 pm Post subject: Re: how to wire a turbo timer on a 138 gti so the a\c works |
| Well I live in the tropic and when I run the car hard say on the track here if like to let the motor run for a 1min or so at idle just to level the temp |
| MALLE |
Posted: Fri Mar 25, 2011 12:39 pm Post subject: Re: how to wire a turbo timer on a 138 gti so the a\c works |
| Yeah I tried that the display come on but that is it now blower are anything |
| Mattie-RS |
Posted: Fri Mar 25, 2011 12:38 pm Post subject: Re: how to wire a turbo timer on a 138 gti so the a\c works |
| bit silly on a NA |
| ExoVyper |
Posted: Fri Mar 25, 2011 12:35 pm Post subject: Re: how to wire a turbo timer on a 138 gti so the a\c works |
well it shouldn't go off... as the timer jst simulates a key being in
have you tried turning the ac back on again? as the little power drop the turbo timer does might be whats knocking it off |
| MALLE |
Posted: Fri Mar 25, 2011 12:26 pm Post subject: Re: how to wire a turbo timer on a 138 gti so the a\c works |
| Well I have mine wired it works fine but the a/c goes off when I take the key out and motor is running I lock the doors using the key not the remote so the car locks and is running on the timer just wanted to know if anyone has a wire setup that keeps the a/c on |
| ExoVyper |
Posted: Fri Mar 25, 2011 12:13 pm Post subject: Re: how to wire a turbo timer on a 138 gti so the a\c works |
you do realise you cant lock the doors with it running?
i've got one and because of that its a tad useless unless im standing near the car |
| nakednakeddave |
Posted: Fri Mar 25, 2011 12:02 pm Post subject: Re: how to wire a turbo timer on a 138 gti so the a\c works |
| erm what....? |
| CD-B3 |
Posted: Fri Mar 25, 2011 11:53 am Post subject: Re: how to wire a turbo timer on a 138 gti so the a\c works |
| Turbo timer on a NA engine? |
| MALLE |
Posted: Fri Mar 25, 2011 11:40 am Post subject: how to wire a turbo timer on a 138 gti so the a\c works |
| hi jus got a apexi timer would love a how to to get it hooked up rigth so the a\c works whn the timer is timing. |
