| Author |
| CD-B3 |
Posted: Mon Jul 25, 2011 2:39 am Post subject: Re: getting oil breather pipe off |
| Push in the yellow button. Get a flat-bladed screwdriver and push it into the small gap between the hose and outlet. Twist the screwdriver and the hose will pop off. |
| Abzynthe |
They are breather filters. I did it that way so that there isnt as much hot air sucked into the intake from the breather  |
| austin316 |
Posted: Mon Jul 25, 2011 2:37 am Post subject: Re: getting oil breather pipe off |
| ooh.. whats them like 2 little air filter bits coming off the pipes? i just have a tube where them 2 are meant to connect? |
| juanfernandes |
Posted: Mon Jul 25, 2011 2:36 am Post subject: Re: getting oil breather pipe off |
I remove it, then the I cut the pipe that goes to the filter off. I did this by shaving off layers until I could see the T pipe, then it pulls off.
The pipe going to the inlet I left it as it was, hence why I only had 1 piece of blue piping, but you could do what Abzynthe has done, and replace both bits.
Basically you wont be able to pull them off - they need to be cut off. |
| Abzynthe |
Posted: Mon Jul 25, 2011 2:20 am Post subject: Re: getting oil breather pipe off |
Found another pic:
| Abzynthe |
| NorthantsBen |
Posted: Mon Jul 25, 2011 2:11 am Post subject: Re: getting oil breather pipe off |
What engine?
Tried heating/warming up the pipe so it gets more
Flexible etc
Or cut it off. |
| austin316 |
Posted: Mon Jul 25, 2011 2:08 am Post subject: getting oil breather pipe off |
| Hi all, i have tried to get my oil breather off to fit my induction kit, but i cant get it off. is this just me being idiot and give it some proper brute force? I have got the 'yellow' clip bits off of like the rocker cover, but where it goes into the kind of T junction bit, i cant get that pipe off... I dont know if that made any sense, am tying to find a pic as my phone isnt uploading for some reason. Thanks |
