| Author |
| MrBSI |
Posted: Sat Nov 05, 2011 11:38 am Post subject: Re: how do you remove rear door cards (3 door) |
| Seabook wrote: |
| MrBSI wrote: |
| Seabook wrote: |
done that today, easier than i would have though.
just wonder what does that orange plug on the front seatbelt do? |
Pyrotechnic seatbelt pretensioner  |
if that is unplugged, would the air-bag still work? |
Nope, airbag warning light should also be on. |
| Seabook |
Posted: Sat Nov 05, 2011 9:10 am Post subject: Re: how do you remove rear door cards (3 door) |
| MrBSI wrote: |
| Seabook wrote: |
| MrBSI |
Posted: Sat Nov 05, 2011 8:55 am Post subject: Re: how do you remove rear door cards (3 door) |
| Seabook wrote: |
| Seabook |
Posted: Sat Nov 05, 2011 8:53 am Post subject: Re: how do you remove rear door cards (3 door) |
| craigy00craig |
Posted: Sat Oct 29, 2011 11:59 am Post subject: Re: how do you remove rear door cards (3 door) |
| Cheers will give it a go in the morning |
| shell-vt |
Posted: Sat Oct 29, 2011 11:58 am Post subject: Re: how do you remove rear door cards (3 door) |
| yer carfull though thet tend to snap... |
| Lee |
Posted: Sat Oct 29, 2011 11:55 am Post subject: Re: how do you remove rear door cards (3 door) |
| Small flat bladed screw driver to flick the top cap off, then a T10 or T15 screw |
| craigy00craig |
Posted: Sat Oct 29, 2011 11:50 am Post subject: Re: how do you remove rear door cards (3 door) |
| Yer undone that taken it off but then how do i get the top part of the belt off the height ajuster part on the b pillar |
| shell-vt |
Posted: Sat Oct 29, 2011 10:31 am Post subject: Re: how do you remove rear door cards (3 door) |
| 17mm bolt at the bottom. were the black bar is on b-pillar undo that it,ll be coverd by a plastic cap .. . 2min job |
| craigy00craig |
Posted: Sat Oct 29, 2011 10:14 am Post subject: Re: how do you remove rear door cards (3 door) |
| Ok thanks. how do you get the seatbelt off the b pillar? |
| shell-vt |
Posted: Sat Oct 29, 2011 6:33 am Post subject: Re: how do you remove rear door cards (3 door) |
| unbolt seat belts remove from bar , push belt through hole |
| craigy00craig |
Posted: Sat Oct 29, 2011 6:07 am Post subject: how do you remove rear door cards (3 door) |
I cant get the rear cards out of my car. How do you get the seatbelt through them? Really stuck on this please help  |
