Author Message
hayes_ctfc
PostPosted: Wed Feb 15, 2012 3:18 pm    Post subject: Re: Take Upper Grille Off
What size and what headed screwdriver do I use to get the badge off the moulding under the lights? A broken upper grille, and a gaping hole in a pair of Lyle and Scott gloves later, the badge still isn't off Sad
PostPosted: Wed Feb 15, 2012 11:41 am    Post subject: Re: Take Upper Grille Off
If its the ones on the black plastic: flathead screwdriver under the smaller top circle and pull up. They are called mushroom clips and it's obv. why.
On the end of the grill (into the wing): just pull. Never snapped mine, but of they do new ones are next to nothing.
PostPosted: Wed Feb 15, 2012 11:36 am    Post subject: Re: Take Upper Grille Off
Just give it a real good yank. The clips are pennies from peugeot if you break them. They do need a bit of force if they have been sat there a while though
nathanmcauley
PostPosted: Wed Feb 15, 2012 11:33 am    Post subject: Re: Take Upper Grille Off
I want to do the same! It looks soo easy but soo hard. I want to remove the upper grille and cover it in carbon fibre vinyl! I got my car buffed and polished and now the paint is peeling, looks a mess Sad
hayes_ctfc
PostPosted: Wed Feb 15, 2012 11:24 am    Post subject: Take Upper Grille Off
By the looks of things, it looks as though it's only held on with some plastic rivet clips, do these just pull/break out or do they have to be surgically removed because mine don't seem to want to move anywhere.
All I wanna do is to paint the Lion on the front
HEELLPPPPPPP!!!
