Author Message
Scusbucked
PostPosted: Fri Mar 09, 2012 4:26 pm    Post subject: Re: How to soundproof front doors
Cheers guys, ty!
Ash
PostPosted: Fri Mar 09, 2012 4:13 pm    Post subject: Re: How to soundproof front doors
Remove the foam, and replace it once you're done. Though when I did mine, I covered the door with deadening, then placed the foam on top with new glue.
2Oh!6
PostPosted: Fri Mar 09, 2012 4:01 pm    Post subject: Re: How to soundproof front doors
Just remove it, recommend Silent Coat for deadening.
Bassline_Toad
PostPosted: Fri Mar 09, 2012 3:41 pm    Post subject: Re: How to soundproof front doors
I used the VIBE sound deadening material (Which might be a way to go) - But for the price you pay for the VIBE stuff, you may aswell go onto eBay and buy some cheap stuff - It all does the same stuff.
138Andy
PostPosted: Fri Mar 09, 2012 1:51 pm    Post subject: Re: How to soundproof front doors
you can rip off the thin foam piece and pack the door with Sound Absorbing Foam (M8050)
www.swanflight.com/sou...e=googleps
you can get it there or cheaper on ebay but be sure to replace the thin foam you strip off or all you will hear is the thin bit of metal thats attached to the lock rattle Smile good luck with this Smile
Scusbucked
PostPosted: Fri Mar 09, 2012 1:19 pm    Post subject: How to soundproof front doors
Need some help with soundprofing my doors. During the winter the spikes on the wintertyres are quite loud on the motorway.
I have looked into some options, but was wondering what to do about the thin foam piece that is attached to the door. Will that need to come off? Someone told me its there mainly to absorb moisture, hence not sure whether I should lay the soundproofing coat on top of it.
Your help is much appreciated.
