Author |
thatplace |
Posted: Tue Sep 18, 2012 4:01 pm Post subject: Re: Spray centre console |
devildriverxii wrote: |
it's where I always mess up, runs like Usain Bolt. |
putting too much on at a time then, light/thin coats |
devildriverxii |
Posted: Tue Sep 18, 2012 3:41 pm Post subject: Re: Spray centre console |
Go easy on the lacquer.
DeadEyePaul |
Posted: Mon Aug 13, 2012 4:57 am Post subject: Re: Spray centre console |
Almost Haynes! There's 2 torx t20's under the clock surround.
Clock
Surround is removed by pushing it towards the windscreen. Then there is those two bolts I mentioned earlier.
Undo those and give it a tug towards you |
hayes_ctfc |
Posted: Mon Aug 13, 2012 4:44 am Post subject: Re: Spray centre console |
Is it just a case of prying it off with a flathead to remove it? |
btownsend06808 |
Posted: Tue May 01, 2012 4:43 pm Post subject: Re: Spray centre console |
Jensen wrote: |
I sprayed mine the other week really simple to do, and got a great finish |
How did undo yours ? |
Jensen |
Posted: Tue May 01, 2012 12:41 am Post subject: Re: Spray centre console |
Lowercase |
Posted: Tue May 01, 2012 12:09 am Post subject: Re: Spray centre console |
and a sod load of rubbing down. and flatting back. |
btownsend06808 |
Posted: Mon Apr 30, 2012 5:18 pm Post subject: Re: Spray centre console |
Cool cheers so just primer paint then lacquer ? |
QuArTz |
Posted: Mon Apr 30, 2012 5:16 pm Post subject: Re: Spray centre console |
In exactly the same way as colour coding rub strips.
Use plastic primer and away you go... |
btownsend06808 |
Posted: Mon Apr 30, 2012 5:00 pm Post subject: Spray centre console |
Best way to do this any tips ?? |
