| Author |
| lozzybaby7 |
Posted: Thu May 31, 2012 11:00 am Post subject: Re: To remove roof trim |
Thank you  |
| MrBSI |
Posted: Wed May 30, 2012 1:20 pm Post subject: Re: To remove roof trim |
I take it you mean the black plastic trim on the roof?
There is another little clip at the other end, open the tailgate & you will see the plastic end cap with the rivet.
New rivets are cheap from any Peugeot / Citroen main dealer ( if you go Citroen you will need to provide the part numbers )
You can use the old clips if there ok. |
| lozzybaby7 |
Posted: Wed May 30, 2012 1:16 pm Post subject: To remove roof trim |
I am trying to replace my roof trim as some noobs tried stealing mine and they are ruined. To remove is it only the little clip by the windscreen that I remove or is there anything else?
Also when replacing new one, can I re-use the clips from old one ?
If anyone could help it would be great  |
