| Author |
| paul_c |
Posted: Mon Jul 02, 2012 10:49 am Post subject: Re: How to... find a ignition Live Wire under the hood ? |
| Do you still have the receipt for the daytime running lights? |
| tinytoontown |
Posted: Mon Jul 02, 2012 7:21 am Post subject: Re: How to... find a ignition Live Wire under the hood ? |
| DeadEyePaul wrote: |
"every wire i Tested was not a live one
not that i have tried all of them, there are far to many to put little holes in"
ergh! i wouldnt be suprised if you blew a fuse! or worse, fried your ECU. this is not the way you should go about testing wires.... |
thanks
I did use a volt meter, and nothing has stoped working |
| sulli |
Posted: Mon Jul 02, 2012 7:19 am Post subject: Re: How to... find a ignition Live Wire under the hood ? |
| positive of battery with a in-line fuse? |
| Seabook |
Posted: Mon Jul 02, 2012 6:14 am Post subject: Re: How to... find a ignition Live Wire under the hood ? |
wire it through the engine bay fuse box.
so live wire from the battery, relay in between and then switch via the fise box (ignition) |
| MrBSI |
Posted: Mon Jul 02, 2012 5:55 am Post subject: Re: How to... find a ignition Live Wire under the hood ? |
You would be better of wiring them in to the double relay under the engine ecu.
If you used a relay you could have it so when the headlamps are switched on the DRL's are then switched off. |
| DeadEyePaul |
Posted: Mon Jul 02, 2012 5:48 am Post subject: Re: How to... find a ignition Live Wire under the hood ? |
| tinytoontown |
Posted: Mon Jul 02, 2012 5:43 am Post subject: How to... find a ignition Live Wire under the hood ? |
Appologies if this has been answered somewhere already, if it has please direct me to the answer...
I need to connect to a wire (Day time lights) which is made live when the Ignition is switched on...
i have searched the loom on the far right of the engine compartment with no luck.. every wire i Tested was not a live one
(yes i could link in to the light loom, but this would mean switching the lights on, which i dont want to do)
if you have a pic to help me out i would be grateful
thanks in advance |
