Author Message
chief93
PostPosted: Fri Jul 13, 2012 10:28 am    Post subject: Re: sub wiring help? please
cheers that was the answer i was looking for, just wanted to check it wouldnt affect the sound quality too much?
Abzynthe
PostPosted: Fri Jul 13, 2012 10:20 am    Post subject: Re: sub wiring help? please
Just get another rca splitter and plug that into the splitter you already have?
chief93
PostPosted: Fri Jul 13, 2012 10:18 am    Post subject: Re: sub wiring help? please
yh cheers iain ive already bought one of them though to power both my speakers as ive got two sets of rca's to run off only one output. so should i buy another and run a splitter off another splitter? or is there another way?
Cheers
iainlovatt
PostPosted: Fri Jul 13, 2012 9:01 am    Post subject: Re: sub wiring help? please
you need some male - femail phono adapters like clicky
PostPosted: Fri Jul 13, 2012 8:58 am    Post subject: Re: sub wiring help? please
Please keep it to one post for the samething no need for the 4 post you had posted.
chief93
PostPosted: Fri Jul 13, 2012 7:44 am    Post subject: sub wiring help? please
Just after some advice really. ive got my front and rear speakers powered off an edge amp at the back but i want to also install a sub which will come with an amp fitted already (this one www.ebay.co.uk/itm/FU1...89wt_1185)
but the problem i have is that my head unit only has two outputs as seen in the pictures for rca's. I've already bought an rca splitter to allow both my speakers to be plugged in. what should i do to install the sub? because another output is needed for the sub rca's i thought?
any help is much appreciated thanks!
