| Author |
| Lee |
Posted: Fri Jul 20, 2012 1:07 pm Post subject: Re: drilling out the lock barrel? to remove ignition barrel? |
£32.50 and I'll get one shipped to your door.
Valet style key, matched to your locks and you can get it coded so it starts the car too! |
| seany_brown |
Posted: Fri Jul 20, 2012 12:54 pm Post subject: Re: drilling out the lock barrel? to remove ignition barrel? |
What info do I need to ggive to get a new key cut n coded ? And won't that cost a lot  |
| NorthantsBen |
Posted: Fri Jul 20, 2012 11:24 am Post subject: Re: drilling out the lock barrel? to remove ignition barrel? |
| MrBSI wrote: |
Would have been far easier just to get new keys cut & coded  |
i had no door locks (had been removed by last owner) and barrel kept getting stuck. £10 for all the locks/barrel and keys from scrappy so couldnt moan lol. just had some fun with old one  |
| MrBSI |
Posted: Fri Jul 20, 2012 11:20 am Post subject: Re: drilling out the lock barrel? to remove ignition barrel? |
| NorthantsBen |
Posted: Fri Jul 20, 2012 11:19 am Post subject: Re: drilling out the lock barrel? to remove ignition barrel? |
big ass screw driver also works, found that out on me old locks.  |
| MrBSI |
Posted: Fri Jul 20, 2012 10:35 am Post subject: Re: drilling out the lock barrel? to remove ignition barrel? |
| seany_brown wrote: |
| is there an easier way to replace the ignition barrel without drilling |
Get a key cut from the VIN number info then you can turn the ignition barrel to the service position & it will slide out. |
| Lee |
Posted: Fri Jul 20, 2012 6:02 am Post subject: Re: drilling out the lock barrel? to remove ignition barrel? |
| You should have said, I could have supplied you with a key to match all your original locks. |
| seany_brown |
Posted: Fri Jul 20, 2012 5:49 am Post subject: drilling out the lock barrel? to remove ignition barrel? |
| Lost my keys but I have a new ecu and all locks changed except the ignition barrel, has anyone drilled one out or is there an easier way to replace the ignition barrel without drilling, cheers Sean |
