| Author |
| jk206 |
Posted: Sat Jul 21, 2012 7:09 am Post subject: Re: how to remove upper front grill (with badge) |
| Got the grill off and headlight changed this morning, was easier than I thought! |
| 206boyracer |
Posted: Fri Jul 20, 2012 4:17 pm Post subject: Re: how to remove upper front grill (with badge) |
| MrBSI wrote: |
If you break any of the plastic clips then a Peugeot / Citroen main dealer ( whichever is nearer to you ) will have them in stock & main dealer will be cheaper then getting ripped of on Ebay  |
Or just fill your pockets when you go scrapyard next.  |
| marc206 |
Posted: Fri Jul 20, 2012 3:21 pm Post subject: Re: how to remove upper front grill (with badge) |
| lukesaunders91 wrote: |
| MrBSI wrote: |
| jk206 wrote: |
| as simple as that? cheers for help |
Its a Peugeot, they are basically held together with clips & torx bolts  |
| MrBSI |
Posted: Fri Jul 20, 2012 12:10 pm Post subject: Re: how to remove upper front grill (with badge) |
| HTIDJamie |
Posted: Fri Jul 20, 2012 12:06 pm Post subject: Re: how to remove upper front grill (with badge) |
| DeadEyePaul wrote: |
Ok it's pretty simple!
Open the bonnet and there's a plastic grill that has slats this is held on by 4 mushroom clips. My favourite tool to remove those is a fork. Once they are out at the bottom of that plastic slat thingy there are clips that you need to push in and at the same time you need to pull it out. Once you got them all out it will reveal a bolt hiding behind the Peugeot badge and there's 2 either side of the badge (3 in total)
Now you have to grab the edge of it (by the wing, below the headlight) and pull! Be warned it's held on by clips and those can be brittle, can buy replacements on the cheap from Peugeot parts! If you have strong finger nails you can tug it off by using those... If not something wrapped in duct tape will do (like a blockbuster membership card?) to stop scratching of the paint |
u love your blockbuster membership cards dont ya
i need to get one  |
| DeadEyePaul |
Posted: Fri Jul 20, 2012 11:06 am Post subject: Re: how to remove upper front grill (with badge) |
| L5_UKS |
Posted: Fri Jul 20, 2012 10:46 am Post subject: Re: how to remove upper front grill (with badge) |
| MrBSI wrote: |
| jk206 wrote: |
| MrBSI |
Posted: Fri Jul 20, 2012 10:37 am Post subject: Re: how to remove upper front grill (with badge) |
| jk206 wrote: |
| jk206 |
Posted: Fri Jul 20, 2012 9:41 am Post subject: Re: how to remove upper front grill (with badge) |
| MattyP |
Posted: Fri Jul 20, 2012 9:31 am Post subject: Re: how to remove upper front grill (with badge) |
| Remove the the black plastic clips which are just above the bonnet catch, then unscrew the bolts x2 (1 either side) of the badge itself then pull the edges of the grille where they meet the front wings |
| Lee |
Posted: Fri Jul 20, 2012 9:29 am Post subject: Re: how to remove upper front grill (with badge) |
Take the mushroom clips off, and it pops off at either side.
5 minutes tops |
| Seabook |
Posted: Fri Jul 20, 2012 9:28 am Post subject: Re: how to remove upper front grill (with badge) |
| a few bolt and just pull it out |
| jk206 |
Posted: Fri Jul 20, 2012 9:03 am Post subject: how to remove upper front grill (with badge) |
how do i remove the front grill on a 206? as i need to replace the near side headlight and to do so i need to take this off. pictures would be great
cheers |
