| Author |
| coopskin |
Posted: Thu Nov 15, 2012 12:13 pm Post subject: Re: Connecting h7 headlights to h4 socket using this connection |
| I have the required Valeo harness for this mod. Look at 206info.co.uk/Forums/v...51059.html |
| MrBSI |
Posted: Thu Nov 15, 2012 9:59 am Post subject: Re: Connecting h7 headlights to h4 socket using this connect |
Why bodge like this when for less then £8 you can get the 2 x grey H7 connector plugs & the 6 terminal pins from any Peugeot / Citroen main dealer & do the job correctly  |
| nemesislee |
Posted: Wed Nov 14, 2012 7:09 pm Post subject: Re: Connecting h7 headlights to h4 socket using this connection |
Thanks very much  |
| nemesislee |
Posted: Wed Nov 14, 2012 7:08 pm Post subject: Re: Connecting h7 headlights to h4 socket using this connection |
Awesome  |
| NorthantsBen |
Posted: Wed Nov 14, 2012 7:07 pm Post subject: Re: Connecting h7 headlights to h4 socket using this connection |
if the connectors fit to the h7 bulbs then they will work, just make a little hole in the the rear case of the lights, feed the cables in and connect them up, seal the hole bit of silicone.
red will be dipped and blue full beam iirc |
| nemesislee |
Posted: Wed Nov 14, 2012 7:04 pm Post subject: Re: Connecting h7 headlights to h4 socket using this connection |
| I've used this to connect a set of angel eyes (which I give up on) and both the h1s worked using it and these seem to fit onto a h7 bulb too |
| NorthantsBen |
Posted: Wed Nov 14, 2012 6:59 pm Post subject: Re: Connecting h7 headlights to h4 socket using this connection |
| if the little spade connectors fit onto the blubs spades then yes. |
| nemesislee |
Posted: Wed Nov 14, 2012 6:57 pm Post subject: Connecting h7 headlights to h4 socket using this connection |
| I have this connection and a set of GTI headlights on the way, can I use this to connect them up to my h4 connector? I've tried on the other forums but no one is replying  |
