Author Message
PostPosted: Thu Feb 14, 2013 2:57 am    Post subject: Re: oil sump
Wouldn't be a bad idea just in case it's picked up and debris from the old sump.
Peachy4878
PostPosted: Wed Feb 13, 2013 5:36 pm    Post subject: Re: oil sump
i take it that its worth changing the oil filter whilst down removing the sump??
Peachy4878
PostPosted: Wed Feb 13, 2013 5:34 pm    Post subject: Re: oil sump
cheers guys
Deano
PostPosted: Wed Feb 13, 2013 3:33 am    Post subject: Re: oil sump
Undo bolts move bottom engine mount back clean mating surfaces re seal with hi temp gasket sealant and refit bolts wait till dry refill with oil check for leaks job done !
PostPosted: Tue Feb 12, 2013 10:08 pm    Post subject: Re: oil sump
You have the replacement, just use that to work out where the bolts pass through. Simple as really.
imjeeves
PostPosted: Tue Feb 12, 2013 8:30 pm    Post subject: Re: oil sump
Remove the bolts put sealer round and refit bolts. Dosnt even need a how to
Peachy4878
PostPosted: Tue Feb 12, 2013 5:13 pm    Post subject: oil sump
has anyone got a how to on the above, have a gti 180, has a damaged sump but have a replacement sump. mant thanks Very Happy
