| Author |
| Ghosty |
Posted: Tue Apr 30, 2013 7:29 am Post subject: Re: headlight washers |
| you wont need to use a telescopic jet, you could just use a fixed jet, that way you could eliminate the high preasure pump..... |
| MrBSI |
Posted: Wed Mar 27, 2013 11:15 am Post subject: Re: headlight washers |
| gtijames22 wrote: |
| yikes lol |
Told you it was expensive  |
| gtijames22 |
Posted: Wed Mar 27, 2013 10:55 am Post subject: Re: headlight washers |
| yikes lol |
| MrBSI |
Posted: Wed Mar 27, 2013 8:46 am Post subject: Re: headlight washers |
The pump, grommet, hose & 3 way union are used on a lot of other PSA stuff.
The tank, the bumper caps & jets are 206 specific so its still expensive to do. |
| Uz |
Posted: Wed Mar 27, 2013 8:43 am Post subject: Re: headlight washers |
For anyone who want a bit of butt clenching... £448.86 inc VAT for the complete setup.
| MrBSI |
Posted: Wed Mar 27, 2013 8:40 am Post subject: Re: headlight washers |
| QuArTz wrote: |
| What if you could fit a pump from a vehicle with washer jets to the original washer bottle? |
It would work but the bottle is only about 3 litres so could need topping up a lot more often.
The headlamp washers need lots of fluid pressure to lift them up against the spring pressure inside the jet body pulling them back down. |
| QuArTz |
Posted: Wed Mar 27, 2013 8:18 am Post subject: Re: headlight washers |
| gtijames22 |
Posted: Wed Mar 27, 2013 7:10 am Post subject: Re: headlight washers |
| MrBSI wrote: |
| gtijames22 wrote: |
| unless the pump cant handle the extra load. |
It cant.
You need to use the correct high capacity pump else the headlamp washers wont have the pressure there to be able to lift & then squirt. |
ahhhh, thats fair enough mate, looks like a costly job then. |
| MrBSI |
Posted: Wed Mar 27, 2013 5:47 am Post subject: Re: headlight washers |
| gtijames22 wrote: |
It cant.
| gtijames22 |
Posted: Tue Mar 26, 2013 8:23 pm Post subject: Re: headlight washers |
| thats the route i was thinking about going for, cutting the bumper and splicing into the windscreen wash pipework, surely cant be that hard, unless the pump cant handle the extra load. |
| QuArTz |
Posted: Tue Mar 26, 2013 6:33 pm Post subject: Re: headlight washers |
| I was wondering if the washer jets off a 307 could be retro fitted, modding the bumper and adding a 'T' connecter and extra pipe work.. |
| gtijames22 |
Posted: Tue Mar 26, 2013 5:40 pm Post subject: Re: headlight washers |
| is this not for proffesional use only? |
| gtijames22 |
Posted: Tue Mar 26, 2013 5:27 pm Post subject: Re: headlight washers |
thanks mate  |
| MrBSI |
Posted: Tue Mar 26, 2013 5:11 pm Post subject: Re: headlight washers |
| gtijames22 wrote: |
| seriously, can u link the parts so i can have a look, then maybe i can improvise with cheaper bits |
Use Peugeot Service box
public.servicebox.peug...Parametres
You will need to make up your own FREE account to use it. |
| gtijames22 |
Posted: Tue Mar 26, 2013 4:49 pm Post subject: Re: headlight washers |
