| Author |
| ssjgoku101 |
Posted: Thu May 02, 2013 10:17 am Post subject: Re: Rear ABS sensor change |
Okay I've changed it now.
These sensors are a b***h to change when seized.
Procedure if rear sensor is seized:
Remove calliper, disc and heat shroud, lob the top plastic head of the sensor off with a screwdriver and hammer. Smack the sensor out through the other side of the bore hole, taking care not to damage the ABS ring. Use needle nose pliers to pull it out through the hub. May need to break off the tip of the sensor to allow it to fit through the gap on the hub side.
Or... heat up the surrounding area and avoid all of this effort lol.
Cleaned up the ABS ring because it was full of grime. Put the new sensor in and NO MORE ABS FAULT  |
| ssjgoku101 |
Posted: Tue Apr 30, 2013 7:21 pm Post subject: Re: Rear ABS sensor change |
Yeah, I've got a rear ABS sensor fault, had it diagnosed.
Yes it was the blue connector, I followed the wire back and took the screw out but the unit seems to be lodged in there tight. Can't seem to pry it out. |
| Steve206 |
Posted: Tue Apr 30, 2013 1:40 pm Post subject: Re: Rear ABS sensor change |
I was trying to find the removal procedure on my service box, doesn't mention the ABS sensors though. Just unplug the wiring under the wiring under where the rear axle connects to the car, blue connector off the top of my head. Trace the wiring back to the sensor behind the disc, its only screwed in. Removing the disc might be easier.
Have you got a problem with yours? |
| ssjgoku101 |
Posted: Tue Apr 30, 2013 10:19 am Post subject: Re: Rear ABS sensor change |
| Do you need to remove the rear disc to get access to it? Seems a bit of a struggle otherwise. |
| Steve206 |
Posted: Tue Apr 30, 2013 10:18 am Post subject: Re: Rear ABS sensor change |
| Seems fairly straight forward when ive looked at mine. |
| ssjgoku101 |
Posted: Tue Apr 30, 2013 9:37 am Post subject: Rear ABS sensor change |
Hi
I'm looking for a guide on removing and changing the rear ABS sensor. It seems much harder to access than the front sensors.
Thanks |
