Posted: Sat Jun 22, 2013 5:03 am Post subject: Re: Induction kit separate breather pipe
Any suggestions?
Majid
Posted: Sat Jun 22, 2013 4:16 am Post subject: Re: Induction kit separate breather pipe
I ain't found nothing that will let me install the breather pipe to my intake pipe
meady
Posted: Sat Jun 22, 2013 4:09 am Post subject: Re: Induction kit separate breather pipe
I'm sure if you buy the air filter for your car and it replaces the black plastic the oiler breather pipe is connected to, then it normally comes with an attachment for it to connect back on to.
Uz
Posted: Sat Jun 22, 2013 3:37 am Post subject: Re: Induction kit separate breather pipe
You don't need an Oil Catch Tank because you've not got a boosted engine.
That's my old XSi's engine bay with breather pipe clipped into the intake pipework...
Majid
Posted: Sat Jun 22, 2013 3:15 am Post subject: Induction kit separate breather pipe
Hi
I want to install a induction kit so I'm gonna remove the original airbox and all the pipes and intake pipe.
The problem is I have a breather pipe attached so I will have to buy a universal kit and the buy a seperate oil catch can and attach it to breather pipe. Will this work
What is the best way of doing this and where would the filter rest on
Bearing in mind the airbox will be removed
