| Author |
| Edward |
Posted: Sun Aug 04, 2013 6:29 am Post subject: Re: Removing throttle Body Plastic Cover |
| On the side you'll see a hole maybe 10mm diameter. Put the screwdriver in there and it will find the screw for the jubilee clip clamping the cover onto the TB. |
| RichardEke |
Posted: Sun Aug 04, 2013 4:49 am Post subject: Re: Removing throttle Body Plastic Cover |
Hello, found this in the how-to section.
www.206info.co.uk/Foru...46523.html
I did this the other day, 3 torx bolts and 15 mins cleaning.
Hopefully this is what you're after, but i may have mis understood, but i'm sure someone will point that out.
Regards, Richard. |
| Lizard2010 |
Posted: Sun Aug 04, 2013 4:20 am Post subject: Removing throttle Body Plastic Cover |
My 206 GTI is idling erratically.
We want to clean the throttle Body.
But an unsure how to Remove throttle Body Plastic Cover
Could someone please advise asap.
In Advance |
