Author |
mtempsch |
Posted: Sat Dec 06, 2014 1:38 pm Post subject: Re: replace central brake lamp |
ukskater01 wrote: |
If I remember correctly open the boot and there is two 10mm nuts to remove and it just pushes out after you unplug it |
Yep, undo nuts, push out, then you get access to the wiring and the washer pipe as the light is pulled out
The rubber gasket between the light and the metal has a tendency to take a good grip, so some persuasion might be necessary to apply to the bolts in order for it to release...
At the rear of the unit there's clipped on bulb holder, the electric connector attaches to the back of the bulb holder. The washer hose attaches to a nozzle in the housing.
Press the two clips on the bulb holder towards the center of the light and separate the holder and housing. 5x T10/W5W wedge bulbs in the holder. |
![](images/spacer.gif) |
ukskater01 |
Posted: Sat Dec 06, 2014 12:22 pm Post subject: Re: replace central brake lamp |
winged_hippo |
Posted: Sat Dec 06, 2014 12:01 pm Post subject: replace central brake lamp |
Hi,
I've faced the above captioned problem. Need to replace lamp but have no clue how to disassemble the cover.
I am looking forward or even forwarder to your tip as soon as possible, but possibly sooner, if possible of course. |
