Author Message
cat41
PostPosted: Tue Jan 13, 2015 2:22 pm    Post subject: Re: rear calipers not working how to service myself
I,ve just fixed the airbag issues, tomorrow its the rear calipers, i,ve strayed wd to help free up the stuck bolts, i stand a good chance in bringing them back from the dead, i used to service motobikes brakes and a cars not too dissimilar. I give it a go anyway.
macj
PostPosted: Tue Jan 13, 2015 2:18 pm    Post subject: Re: rear calipers not working how to service myself
You need to re-plumb your whole system Shocked
cat41
PostPosted: Mon Jan 12, 2015 2:17 pm    Post subject: Re: rear calipers not working how to service myself
Do that just bolt on mine and are able to be used with the handbrake, its far too much work now
macj
PostPosted: Mon Jan 12, 2015 2:05 pm    Post subject: Re: rear calipers not working how to service myself
I have standard GTi rear calipers on the rally car, The cable handbrake just makes MOT standard with new discs and pads but the hydraulic H/B is very good. Locks up both rears every time...... but that's cheating Wink
PostPosted: Mon Jan 12, 2015 8:20 am    Post subject: Re: rear calipers not working how to service myself
The calliper need's replacing, the handbrake mechanism inside will be rusted up - common problem with this design of calliper if there not looked after correctly.
cat41
PostPosted: Mon Jan 12, 2015 7:18 am    Post subject: Re: rear calipers not working how to service myself
Its on 3 clicks,
Project2062014
PostPosted: Mon Jan 12, 2015 6:22 am    Post subject: Re: rear calipers not working how to service myself
cat41 wrote:
Thanks for that info.
Is there any way to improve the rear brakes and manly around the handbrake.
Tighten the hand brake cable .
cat41
PostPosted: Mon Jan 12, 2015 4:32 am    Post subject: Re: rear calipers not working how to service myself
I,m buying a spare set of calipers but will make some tweeks, i,ve got some ideas i will try.
PostPosted: Mon Jan 12, 2015 4:29 am    Post subject: Re: rear calipers not working how to service myself
A pair of service / exchange calipers.
The calipers if not looked after are a known weak spot.
cat41
PostPosted: Mon Jan 12, 2015 4:13 am    Post subject: Re: rear calipers not working how to service myself
Project2062014
PostPosted: Mon Jan 12, 2015 1:36 am    Post subject: Re: rear calipers not working how to service myself
Got loads of fluid init ? No split in brake line .
Take calipers off give clean around the pistons check they move ok ¬ stuck . . Check there is no air in ,or a blocked brake line or leaks.
rear right does stick a little on mine .
Left rear always seems weaker on handbrake (rally drifts ). handbrakes are weak on a 206 for sure .
cat41
PostPosted: Sun Jan 11, 2015 11:13 am    Post subject: rear calipers not working how to service myself
Hi all.
It's looking if the left rear caliper isn't working at all, with handbrake full on a can spin the wheel, also i,ve been out then put my hands on the discs, the rear left is stone cold, the rear right is warm.
I used to service my motorcycle brakes years back and i see the cars ones looking ok to sort.
Any tips on how to keep these calipers alive and kicking?
Its a 1999 gt
