Author |
Addaz |
Posted: Sat Jan 17, 2015 4:42 am Post subject: Re: fitting alloy bottom/crank pulley |
It may on yours if you have a single bolt holding it |
andy83 |
Posted: Fri Jan 16, 2015 12:25 pm Post subject: Re: fitting alloy bottom/crank pulley |
edward your a star mate thanks for that i can get cracking with it tomorrow along with doing the rear brakes and fluid change  |
Edward |
Posted: Fri Jan 16, 2015 12:21 pm Post subject: Re: fitting alloy bottom/crank pulley |
No. On mine the pulley is held on with 4 bolts. It doesn't interfere with the timing belt pulley behind it. |
andy83 |
Posted: Fri Jan 16, 2015 10:45 am Post subject: fitting alloy bottom/crank pulley |
hi everyone i will be fitting the alloy crank pulley tomorrow i was just wondering if the pulley is connected to the timing belt or not?
any advice always appreciated |
