Author |
ToskeGV |
Posted: Thu Feb 12, 2015 9:45 am Post subject: Re: Open chrome lexus back rear tail lights |
Well here in Serbia thay are around 50E if you find them And actualy i like them so i want to try and fix them tnx for advice
and new are 99E :S |
Vexs |
Posted: Wed Feb 11, 2015 5:33 pm Post subject: Re: Open chrome lexus back rear tail lights |
These are designed not to be opened up at all, but doesn't mean it isn't possible.
You have 2 options:
(Remove the bulbs and any loose fittings, screws etc before using either method.)
1.Use a heat gun/ hairdryer on a high heat around the edges to re-activate the glue then pry them apart.
2. Pre heat an oven to around 160-180 and bake the lights for 5mins at a time.
Remove after 5mins and try to pry apart, keep doing this until succesfull.
NOTE: keep the lenses away from touching anything whilst baking.
To re-seal them you need to remove all the old glue and have a clean surface to work from. Use either a waterproof sealant or a no nails like sealant to ensure a water and air tight fit.
I don't honestly recommend splitting them and don't take any responsibilities for what you do to them. You will almost certainly suffer from misting/ condensation issues in the long run.
These lights can be bought for around £10-20 second hand and around £30 new for a pair. Splitting them is a lot of hassle and isn't really worth it; especially as they aren't very desirable. |
ToskeGV |
Posted: Wed Feb 11, 2015 5:08 pm Post subject: Open chrome lexus back rear tail lights |
one of red plastic is broken(bought car like that) so i want to fix it but i dont know how to open this up
any advice?
images.esellerpro.com/...L4002A.JPG this model |
