| Author |
| Steve206 |
Posted: Tue Nov 17, 2015 5:25 pm Post subject: Re: Any way of turning traction control off? 1.4 16V SE? |
| If it has esp as standard the button will be down by the ignition, next to the airbag key. Hold it down to turn it off. |
| JackCharlesRoss |
Posted: Tue Nov 17, 2015 12:53 pm Post subject: Re: Any way of turning traction control off? 1.4 16V SE? |
| Okay, Thanks Addaz, Never used pp2000 but i know what it is, Could you inform me of the correct cables i will need to use it on my laptop? Thanks |
| Addaz |
Posted: Tue Nov 17, 2015 7:46 am Post subject: Re: Any way of turning traction control off? 1.4 16V SE? |
| There should be a button on the dash to turn it off for a short while, or your could deconfiqure it via pp2000 |
| MrBSI |
Posted: Tue Nov 17, 2015 4:08 am Post subject: Re: Any way of turning traction control off? 1.4 16V SE? |
| Unless its going on a track OR its stuck in snow the ESP is best left switched ON. |
| JackCharlesRoss |
Posted: Tue Nov 17, 2015 2:49 am Post subject: Re: Any way of turning traction control off? 1.4 16V SE? |
I can confirm that my car does has ESP  |
| MrBSI |
Posted: Mon Nov 16, 2015 7:55 am Post subject: Re: Any way of turning traction control off? 1.4 16V SE? |
GTI 180, GTI HDI & late GTI had it as standard, for the rest its optional extra.
You do indeed need the motorised throttle body to have ESP on a 206. |
| Edward |
Posted: Mon Nov 16, 2015 6:05 am Post subject: Re: Any way of turning traction control off? 1.4 16V SE? |
| Any petrol with motorised throttle body has esp doesn't it? |
| MrBSI |
Posted: Mon Nov 16, 2015 1:03 am Post subject: Re: Any way of turning traction control off? 1.4 16V SE? |
Ive seen ESP fitted on a ET3 before, someone must have ticked the option box when originally ordering the car.
FWIW: Late GTI have ESP fitted as standard & the GTI HDI has it to. |
| Addaz |
Posted: Sun Nov 15, 2015 6:27 pm Post subject: Re: Any way of turning traction control off? 1.4 16V SE? |
| You have ESP? Im pretty sure only 180s have ESP |
| JackCharlesRoss |
Posted: Sun Nov 15, 2015 1:30 pm Post subject: Any way of turning traction control off? 1.4 16V SE? |
| Just wondering if there is any way to turn traction control off in an se 1.4 16v? Thanks! |
