Author |
southwestchap |
Posted: Wed Jul 27, 2016 8:50 am Post subject: Re: Swap engine from 1.4Hdi to 1.6Hdi |
I'd say crack on if you have the time to play with it.
Yes the 1.6 is renowned for eating turbo's and injector seals. But keep on top of the servicing and be generous with oil changes using OE spec oil and should drive on an be fine. |
![](images/spacer.gif) |
geompj |
Posted: Mon Jul 25, 2016 6:33 pm Post subject: Re: Swap engine from 1.4Hdi to 1.6Hdi |
I have the complete car with 1.6. But, the problem is that here, in my country we drive on left side...and the car is from Uk It will cost me only the time. I'm not sure if this is the right swap to do...that's why i asked |
Sleepy-Gti6 |
Posted: Sun Jul 24, 2016 7:27 pm Post subject: Re: Swap engine from 1.4Hdi to 1.6Hdi |
Personally, I wouldn't go to the trouble of swapping the engine from the 1.4 to the 1.6 HDi. Just buy a car that already has this engine in it. Would save so much time and effort. |
MrBSI |
Posted: Sun Jul 24, 2016 9:53 am Post subject: Re: Swap engine from 1.4Hdi to 1.6Hdi |
The DV6 engine is the biggest pile of w**k PSA Peugeot / Citroen has ever produced.
Find a DW10 equipped 206 & tune that up instead. |
geompj |
Posted: Sun Jul 24, 2016 8:15 am Post subject: Re: Swap engine from 1.4Hdi to 1.6Hdi |
Exhaust would not be a problem. I already have a custom exhaust on 1.4 and i will have to make adaption and DPF off. I was thinking that i will start from 109hp instead of 68hp.
My 1.4 isn't stock, i have Garrett GT15, FMIC, Exhaust, EGR off and boost controller on it... And, if i have the 1.6 engine... for free, i wanna make around 170-180hp from it.
The 1.6 is not that strong as 1.4? |
Steve206 |
Posted: Sun Jul 24, 2016 7:40 am Post subject: Re: Swap engine from 1.4Hdi to 1.6Hdi |
Don't bother. It's a terrible engine. You'll also need the complete exhaust system with dpf and the ad blue tank. |
geompj |
Posted: Sun Jul 24, 2016 6:40 am Post subject: Swap engine from 1.4Hdi to 1.6Hdi |
Hi all,
I'm planing to make a swap engine on my car, replace the 1.4hdi with 1.6Hdi engine.
I already have the complete front of the car with new 1.6hdi engine. My car is from 2005, and the 1.6 from 2004.
My question is, if i change only the engine, gearbox, ecu, bsi, key,fuel pump from the tank(i don't know if is really necessary) and engine wiring will be ok? And not swap the entire wiring of the car. I have the same Ecu on my car, Bosch Injection.
I don't know if there is some difference between wires from the ECU to BSI between 1.4 and 1.6.
Many thanks
George |
